Uniting a sheet body and a solid body
I have a solid body that is sitting on top of a sheet body, and I need them to be combined/united/sewn/stitched, so I can later get a continuous mesh in fem. What is the best way to do this in modeling? I know I can combine two solid bodies with unite and sew, and two sheet bodies with sew, but what about one solid and one sheet body?
RE: Uniting a sheet body and a solid body
Can you show a picture of what you are working with?
Here's what I would do:
1. Extract the faces of the round part: OD, ID, and top face Insert -> associative copy -> extract
2. Put a hole in the sheet body the same size as the OD of the round part. The easy way would be to trim to that face
Insert -> Trim -> trim body -> the flat sheet as the "target" and the extracted OD as the "tool body" -> flip the "direction" if the wrong side got deleted
3. Sew those sheet bodies together ("Hide" the original solid body)
Insert -> combine -> sew
To start with, ALWAYS indicate WHAT version of NX you are using!
But looking at your picture(s) you need to understand that there is NO WAY to combine those two bodies, one a solid and the other a sheet body, into a single body, at least not in NX Modeling.  You should just create a shell mesh of both bodies without any overlap and then use the FEM software to 'stitch' the two meshes together.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I'm using version 8.0. So I need to trim the sheet body by take off the imprint of the OD of the cylinder, leaving me with a sheet body with a hole equal to the size of OD. Then in FEM, stitch the edges of the sheet and solid bodies?
Would I be able to use "Surface coat of 2D elements" instead/in addition to stitching?
I'm not the right person to ask about specific FEM/FEA issues.  All I know is that the handling of non-manifold configurations are the responsibility of the 'modeling' (i.e. meshing) tools in the FEM module.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I'm just guessing based upon past experience with FEA - but I believe you need to think in 2 different ways:  1.) geometry (CAD - solids & sheets) and 2.) FEA (imported solids/sheets & meshes).  Within your FEA software you need to combine the mesh of the solid with the mesh of the sheet where they make contact.  Leave the geometry (CAD side) alone.
Tim Flater
NX Designer
NX 7.5.4.4 MP2
WinXP Pro x64 SP2
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
