dual dimensioning values are the same
I just started a new job using Wildfire 2.0 and this company uses inches with dual dimensions in a high low number which is on the top or bottom acording to dimension. Of course the tolerance's are all diffrent too. I am re-drawing hand drawn parts to Pro and I would like to do it right if possible rather than over ride and type in the numbers. I have set, in properties to inches and have dual numbers but they are both the same. I have a lot of models to create, can sombody help?
RE: dual dimensioning values are the same
It sounds like you have primary and secondary units both set to inches.
Ben Loosli
over 12.240 or 3.1355 over 3.1366. I drew the part at the mean which is what comes up when I dimension a feature but I need the numbers done like above both in inches. I did do the @oxxx and it looks fine but I thought there should be an easier way.
Pete
If you want to show your dimensions as high/low limit values, then set the following drawing optons.
tol_display Yes
tol_mode limits
You do NOT want to override the model nominal values with the @oxxxx format!
Ben Loosli
