easy way to find overlap between bodies?
I am looking over someones design and they did an assembly in a single part file. They made some pins and I want to make sure that there is no overlap between the pins and the rest of the fixture. Is there something simple in the analysis tab to do this. I usually create a live section and look at it, but there has to be a better way. I also have nx5
RE: easy way to find overlap between bodies?
www.nxjournaling.com
