How to check and change elements orientation in Hypermesh
Hi to all,
I am just trying to check and change elements orientation (SHELL elements) in Hypermesh to align all the elements in the same direction, and I am not able to find how. I can find how to change normals and also how to change material orientations (material orientations doesn´t match with elements orientation). Does anybody know how to do it?
RE: How to check and change elements orientation in Hypermesh
I am 97.385% sure this is mentioned in the help.
I think it is called check normals.
Since it is 8 of your earth years since I used hypermesh I can't remember exactly.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Hi Greg thanks for your answer.
Well to check the normals I know how to do it, what I am trying to display and change is the X and Y axis of the elements and to align all in the same direction, in PATRAN is easy to do it but in Hypermesh I can´t find how to do it
