14400:120 PT fuse change
silly question from a green horn. anyone familiar with a load break device to pull this fuse hot? or would the common recommendation be to take an outage. this is on a manufacturing facility that would love to avoid an outage.
also, what have you seen as likely causes for PT fuses to blow?
thanks in advance.
thanks in advance.
RE: 14400:120 PT fuse change
For outdoor applications I have seen hot stick removal.
What kind of PT and where is it located? Have you made any attempt to determine why the fuse is blowing? I would not want to be the person inserting a fuse into a faulted PT.
See the recent thread http://eng-tips.com/viewthread.cfm?qid=320853
on the possible reasons for a blown fuse.
It's impossible to tell if it's a fuse failure or a problem originating from the VT itself. Closing a fuse into a damaged/faulty VT could be dangerous.
Need to check out the VTs prior to trying to re-energize, e.g. megger test, ratio test, and possibly excitation test (if you have comparative results).
