Removing Thin Feature from Sweep
Ok, this may be an elementary question but, I am going to ask anyways, since I always get great answers....
I've used SWEEPS many times, but drawing a blank right now. I have a simple PROFILE and PATH. But it comes out THIN. I remember seeing an option in older versions of Solidworks if you want a thin extruded part. I do not, so where do I go to remove the thin extruded part?
I am use Solidwork 2011, SP2.0.
Again, this may be a elementary question, since I have used Solidworks for years, but crazy, I am stuck, drawing a HUGE BLANK. And nobody else around here is using Solidworks, just I alone.
Thanks in advance
Thanks in advance
RE: Removing Thin Feature from Sweep
CLEAR THOUGHT just hit me.
I was using SURFACE and should have been using BOSS/BASE, duh..
Can you post the path and profile?
