Help with motor and gearing
all,
First off, thanks for reading.
I have a project converting a gravity roller conveyor to a driven one. I have been told that the linear speed is to be 0.3m/min-3.5m/min and that the final drive shiv must be 2.75" in diameter to match the roll. The motor must be 1hp with a vfd.
After some calculations using a 1hp 900rpm motor, I would have to reduce the speed down to 150 rpm with the VFD and reduce it down to 3.76 rpm with a 40:1 gear reducer and then down to 1.367 rpm with pulleys.
For the 3.5m/min which calculates to 15.95 rpm, the motor would have to be sped up to 1754rpm at 116.9Hz, which is almost a 100% increase.
Is there a better way to do this?
Someone please tell me that I am missing something.
Ridley
Ridley
RE: Help with motor and gearing
Firstly, you need to advise the means of driving this conveyor.
I assume from your notes that the existing rollers are 2.75", but how do you intend to impose drive to these rollers(Chain, vee belt, timing belt, flat belt etc) as this will then determine the best means.
So far your calculations are correct:
Linear speed of 0.3 m/min= 1.36 RPM
3.5 m/min= 15.9 RPM
Irrespective of your answer, this is an abnormally large ratio change for a VSD motor under normal circumstances.
You would need to consider external fan type cooling for the electric motor when running at the slowest speed(approx 5 Hz).
Ross
Ridley
2. Ask for design help from your local power transimssion distributor. The people that will sell you the motor and drive components can help with the layout and calculations.
