Subgrade Reaction Closed Form Solution
I'm looking for the closed form equations that describe the correlation between "Phi/Relative Density vs Initial Modulus of Subgrade reaction" shown in the attached graph. I got this from the following source...
American Petroleum Institute (API),
1987, "Recommended practice for planning, designing and constructing fixed offshore platforms", API
Recommended practice 2A (RP 2A), 17th Ed, Figure 6.8.7-1, pp.70
I figured someone on here might know. Thanks,
RE: Subgrade Reaction Closed Form Solution
Check with the source.  Personally, I don't see the value in this...it has little correlative value to actual application.
