Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
Davemcguire (Mechanical)
2 May 12 16:54
I have a silicone plug that is molded over a small circuit board and needs to be pressed into a plastic housing WITHOUT USING ANY LUBRICANT. The plug measures ~ 2"l x .5"w x .75" deep. The plug has 3 horizontal and equally spaced ribs along the pressed in area. Currently the operation of pressing the plug into a plastic housing is being done by hand. A real operator killing process. I'm trying to press the plug in using an automated air driven press but I'm not able to seat the plug all the way with out it springing back. The ribs are also no longer running parallel and are up swept towards the outside.
Any idea's or suggestions would be great.
THanks
Dave
patprimmer (Publican)
2 May 12 18:29
Fix the fit of the ribs.
Heat the female part.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Compositepro (Chemical)
2 May 12 19:29
Make a fixture with slots that fit the ribs tightly so that when you insert your plug you push on the ribs rather than the plug. The slots keep the ribs from distorting.
Close Box
Join Eng-Tips® Today!
Join Us             Close
