Protecting Vehicles from falling off wall.
Okay Engineering types, I have a large parking lot which is bordered at one end by a 16 foot tall Keystone type wall. The top of the wall is at parking lot level(parking lot is on fill). The edge of the wall is 4 feet behind a 6" tall by curb. I have about 100 feet I need to protect. The vehicles are mainly semi-tractor trailers with lots of turning movements in this area. Plus it is down hill from truck parking to wall at a 5% grade. My first thought was a standard CalTrans Guard rail. Then I started wondering if there are more economical methods...Any suggestions? Maybe a tall curb? But how tall?
Thank you.
Thank you.
RE: Protecting Vehicles from falling off wall.
For only 100' of protection, in place of guardrail it could be cheaper to go with some form of a concrete (Jersey) barrier.
I would kind of like to stop her.
An out of control 18 wheeler - good luck
If anyone dares to hit the wall, they won't leave.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Containment kerb is not really meant to be hit square on, but the 300mm/12" upstand should at least give an indication to a driver there was some hazard behind him him if he hit it. Paint it alternately yellow and black and there's a visual deterrent too. However, this would still need some sort of parapet to stop 'determined' drivers.
Bear in mind, also, that tractor trailers have big tires, and a 6" curb might not be much of a barrier to a truck. I'd suggest something much taller, like 12"
