Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
ISDQAQC (Specifier/Regulator)
2 May 12 15:18
Looking over an engineering report, three components to a vessel are given a MDMT of 2. all other components are -20. The CET value is shown as -47 and the equipment MDMT is 2.
the 3 three components are, a bottom shell ring, 30" O.D. nozzle and the repad for the nozzle. all are 1.1250 and SA-516-Gr. 70. The resolution is for a brittle fracture assessment in accordance with API 579-1. I would welcome all assistance. thank you..
SJones (Petroleum)
3 May 12 3:40
What are the MAT values?
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
metengr (Materials)
3 May 12 7:52
In addition to MAT, which can be the minimum design metal temperature using ASME Section VIII, Div 1 design basis, what exactly are you trying to do under API/ASME FFS-1 brittle fracture assessment? Are you trying to re-rate this vessel?
LSThill (Mechanical)
3 May 12 11:56
HAVE YOU REVIEW THE FOLOWING:
API 579-2/ASME FFS-2 2009 Fitness-For-Service Example Problem Manual
ASSESSMENT OF EXISTING EQUIPMENT FOR BRITTLE FRACTURE EXAMPLE PROBLEMS
page 3-1 3-21
3.1 Example Problem 1 ......................................................................................................... 3-1
3.2 Example Problem 2 ......................................................................................................... 3-1
3.3 Example Problem 3 ......................................................................................................... 3-1
3.4 Example Problem 4 ......................................................................................................... 3-2
3.5 Example Problem 5 ......................................................................................................... 3-3
3.6 Example Problem 6 ......................................................................................................... 3-4
3.7 Example Problem 7 ......................................................................................................... 3-6
3.8 Example Problem 8 ......................................................................................................... 3-8
3.9 Example Problem 9 ....................................................................................................... 3-10
3.10 Example Problem 10 ..................................................................................................... 3-11
Close Box
Join Eng-Tips® Today!
Join Us             Close
