developing a theoretical model , looking for answeres
Hello to everyone following this thread . I`m try to develope a theoretical model . I`m looking for answeres in several disciplines . Re ; electrical theory and radio theory my questions are ,
Waves can be broken into two types , Linear - sine waves and Non Linear standing or stationary waves ??
Sine waves can be detected and measured over time as a function of frequency ?
Standing - stationary waves can be detected and measured over space , and as such can be called a function of space ?
Re; general radio theory . As frequency increases propagation over space decreases ??
If true , As frequency decreases propagation over space increases ?
Re ; radio theory . Is band width a function of
frequency ?
If so , as frequency increases - band width increases ?
Likewise , As frequency decreases - band width decreases ?
Re ; electrical theory & radio antennas
Operating at extremely low RF frequencies is it possible to create a virtual antenna if frequency of operation and voltage applied to a antenna are phase synch`d
, In essence the field becomes the antenna ???
Any and all answere`s appreciated
Best regards mangomike
frequency ?
RE: developing a theoretical model , looking for answeres
Standing waves are a function of impedance, not space. They are what happens when the load at the end of the transmission line is a different impedance from the transmission line.
Propagation - path loss in space is constant. In the atmosphere, it is a function of frequency.
Bandwidth - it is a function of the modulation rate of the carrier. You can have a 1 Hz wide carrier at any frequency as long as it is not modulated. Adding modulation increase the bandwith used by the carrier.
Virtual antenna - I don't understand the question.
Thanks for the response . I`m sorry for the confusion I will rephrase my questions and give examples .
Digital radio recievers operate by detecting and measuring changes in ; Frequency , Amplitude and / or Phase - correct ?
Generally speaking the RF signals / waves are linear as they travel through space - correct ?
Linear wave propagation characteristics typically decrease as frequency increases . Example ; satelite communications in the UHF - SHF + is LOS (line of sight) and does not propagate to the other side of the planet .
Like wise submarine signalling -communications will use VLF - ULF because of the penetration and increased range and propagation , Although sending a group of letters - numbers via telex takes time due to the low frequencies their operating on and reduced bandwidth . The same reason OTH ( over the horizon ) radar systems employ the use of the HF (high freq. ) band for detection and ranging because of the increased distances due to the band characteristics .
Another example of bandwidth increasing as higher and higher frequencies are used is ; fiber optics .
The statement I`m trying my best to confirm is
" as frequency is increased in the E/M spectrum propagation over distance generally decreases " . ??
As for the non linear standing wave question I`ll save that as a reply on this thread , Believe me I`m not trying to pull teeth here just dialog . One step at a time : )
Thanks in advance for a response .
Digital radio - all three are correct.
Submarine signalling - this uses a surface wave for propagation, not a space wave, and they use enormous amounts of power: try 2 times 10 to the 9th power watts.
Fiber optics - bandwidth is limited by inefficient optical filters. Theoretically, you can still get a signal of 1Hz bandwidth down a fiber.
More later.
