Measuring face pressure
Is there a way to measure face pressure in a gear tooth without destroying the tooth, or how can it be done with minimum intrusion into the material?
RE: Measuring face pressure
There are companies that sell paper thin products that will approximate the loads.  Not sure that will work for you - but maybe?
Create a model for photoelastic analysis.
Ted
Thanks for the input. I think maybe DLiteE30 link is something to investigate further. Thanks
