Questions about drawings
2 questions:
1) is there a way to automatically put my dimension/annotation/centerlines etc. in another layer then my drawing views? Currently, the only way I can do this is select them manually and use the move to layer command.
2) When using the 2D exchange feature, is there a way to export multiple sheets to 1 dxf/dwg? Changing the option in the tab "data to export" doesn't seem to do anything.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Questions about drawings
or was it 1992 ?
Tomas
I had quick and simple GRIP programs and icons to switch layers between drafting layer settings and model layer settings.
Ben Loosli
www.nxjournaling.com
I don't, so that won't be a problem. I guess changing the work layer between placing the views and placing the dimensions will be the easiest way to make it work.
Toost, if you still have the number of the ER I'd be happy to sign my name under it :)
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
