conversion metric bolt to whitworth bolt
Hi All,
our exsisting line using bolt M64X6 Gr8.8, what the suitable bolt size if we want replace it to withworth (inch) bolt ?
please advise for bolt size and bolt material
regards
RE: conversion metric bolt to whitworth bolt
  Changing to an inches based thread is one thing,  but` are you really sure  you want to go Whitworth??  I dont think Ive seen Whitworth used since the British Motorcyle industry started to go down hill in about 1958
As above, why did you name Whitworth?
What ever you change it to, change both the bolt/stud AND the nut.
Use a larger bolt and nut, don't ever "translate" into a smaller size.  Since your flange and vessel are already built, you will need to measure the holes for the maximum new/replacement bolt/stud dia.
An 8.8 is similar to a USA [SAE J429] grade 5.  For flange bolting, I would upgrade to SA-193 Gr. B7 studs and 2H nuts.  This is the standard bolting for pressure piping in North America / ASME items.
M64 is about 2½-inches.  I would purchase 2½-UN8 studs.  2½-inch nominal OD, 8 threads per inch.  Standard stuff for USA.
