Is it possible to add text/annotation "below" a dimension line
In UG NX7.5 is it possible when adding dimensions to add text/annotaions "below" the actual dimension line & not just below the dimension value itself?? I'm new to UG NX after 15 years of using ProE.
RE: Is it possible to add text/annotation "below" a dimension line
You'll have to create the appended text as a separate note and position it where you would like it.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Sorry, I was wrong.
Ignore my answer and consider John Baker's.
To add to John's post, you can also use the origin tool (Edit -> Annotation -> Origin) to associate your new text note to the dimension. Then, if you move the dimension or view, the note will follow.
www.nxjournaling.com
