Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the site is just incredible....I am learning more here than anywhere else before and am looking forward to being able to help someone .... this is my idea of what the Internet is supposed to do..."
Geography
jdm2008 (Industrial)
1 May 12 16:51
I need to grind about(.015-.030) a quarter inch from the bottom of a leaded glass sheet so it can fit into a sliding track to make the glass thinner.  I was surprised when the I called the guy who does some other processing steps tell me he could not do this.
Is there some reason why this is a difficult undertaking?  Obviously the glass does not have to be clear for the portion that is ground.
Ceramicguy (Materials)
1 May 12 17:08
He probably declined due to the risk of lead exposure from the PbO in the glass.  You might ask him if it was a technical issue or health and safety issue that prompted his response.
Bruce
www.accuratus.com
berkshire (Aeronautics)
1 May 12 17:41
You might also ask if the glass was tempered or plate.
Grinding on tempered glass tends to produce glass crumbs.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
MiketheEngineer (Structural)
1 May 12 18:07
Yep - to both
btrueblood (Mechanical)
1 May 12 18:09
Even if wet grinding (reducing dust exposure to the operator), waste disposal might be an issue too.
swall (Materials)
2 May 12 9:55
I have to question the comments that lead in leaded glass is a health issue. Anybody got a sound basis for this?
2 May 12 10:17
Like all health issues, swall, it's arguable.  And these days, it's pretty tough to argue the "don't worry about it" side with people educated by what the media tells them.
Lead oxide is a component of true lead glass, somewhere between 20 to 40%.  Lead oxide is also the white pigment used in leaded paint, and you ought to know that anybody sanding on leaded paint surfaces these days must "suit up" and wear respirators, etc.  Lead oxide is toxic, and will leach into acidic solutions in lead glass; wine stored in a leaded glass decanter reaches unsafe limits (well, relative to drinking water standards) in a day or less.
Lead is a cumulative poison in the human body, so avoiding exposure is fairly important.  In my town, a lot of the schools have no drinking fountains right now, they are turned off because testing showed high lead levels (probably from the use of leaded brass in the plumbing/fixtures).  Yes, the simple and smart answer is to let the faucet run for a few cupfuls before drinking, thus flushing the leachant-filled water down the drain...but we're talking public politics and that don't mix well with "smart".
Given the hassle over disposing of batteries, I'd guess there would be equivalent hassle over disposal of lead oxides, thus my comment regarding the swarf disposal.
There are non-lead versions of lead glass that give similar refractive index.  It's where I'd look, if only to avoid the hassle.
More here: http://en.wikipedia.org/wiki/Lead_glass
chicopee (Mechanical)
2 May 12 10:45
Wouldn't grinding the edge of the tempered glass sheet craze the whole sheet instead of producing glass crumbs?
2 May 12 10:49
Thanks for the help everybody.  I do not think the reason is a health issue since the same supplier also cuts the class with a milling machine.
I will have to get back with more details.
swall (Materials)
2 May 12 11:12
Very informative, btrueblood.
2 May 12 12:37
""" Wouldn't grinding the edge of the tempered glass sheet craze the whole sheet instead of producing glass crumbs?"""
Yes the whole sheet crazes and disintegrates into little pieces the size of breadcrumbs.
 Thats what I meant when I said " Glass crumbs"
B.E.
2 May 12 13:15
"I will have to get back with more details."
Did you give your vendor a drawing showing what you wanted?  Pictures, thousands of words, yada yada.
Close Box
Join Eng-Tips® Today!
Join Us             Close
