Remove a color using "No Color"
thread560-129853: Programmatically change the color of a part?
Catia V5 R18 on XP, VBA
I am working in the context of a CATProduct which does contain many levels of "assemblies" (components). Those components have different attribute such as the assembly type and the status (Shared SH, Release RL and Frozen FR in my case). I order to help designer to filter their catproduct on the attributes for DMU purpose I created an user form which allow the designer to color all assemblies at the FR status or all assemblies RL status.... so once the designer has selected what he wants the data is colored, the color is applied on the assembly level which color the parts by inheritance. So the color of of the assembly is changed from "No Color" to a RVB color (SelectionX.SetVisibleColor()). Now if I want the designer to be able to proceed again and color another selection I need to be able to remove the colors I just applied. That is for the context of what I am trying to do.
The question:
What is the VB code to apply a "No Color" value on an part which has been selected? (properties-> graphic-> graphic properties-> color-> "No Color).
I hope I was clear in the description of my issue (I know how to do the selection just I do not know how to remove the color I just applied on an assembly without closing the catprodut).
Any help would be appreciated.
Thank you
Alexandre Bessy
RE: Remove a color using "No Color"
No clues?
sad
I have looked at this in Knowledgeware to set a hole back to NONE but could only set to the default colour hex code of "#D2D2FF"  There are some things you can not access in the API or language browsers.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
I afraid of something like that but I really appreciate you taking the time to look into it.
Thank you
Alexandre Bessy
Hi
All these are old codes , I didn't tested on newer versions of CATIA. Hope I understood well your problem and maybe this can help you a little bit in your search.
In a CATScript, code to reset graphic properties (to default, of course):
CODE
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As part
Set part1 = partDocument1.part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item(1)
Dim specsAndGeomWindow1 As SpecsAndGeomWindow
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer3D
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
viewer3D1.Reframe
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
CATIA.StartCommand "* Iso"
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Add body1
CATIA.StartCommand "Reset Properties"
selection1.Clear
Dim cmd As String
cmd = "wscript c:\SendEnter.vbs"
End Sub
Code for vbs file
CODE
Set WshShell = WScript.CreateObject("WScript.Shell")
WScript.sleep 200
WshShell.SendKeys "{ENTER}"
Of course you can do it in vba, it will be much easier.
Or you can use something else (also in CATScript) smile :
CODE
' Purpose:         Change color of the selected elements
Option Explicit
Sub CATMain()
    Dim TabSelectedProduct() As Product
    Dim oProductRoot As Product
    Dim oProduct As Product
    Dim iNumberSel As Integer
    Dim iIndexSel As Integer
    Dim iNumberBodies As Integer
    Dim iNumberShapes As Integer
    Dim sInputObjectType(0) As String
    Dim oObject As AnyObject
    Dim r As long, g As long, b As Long
    Dim layer As long
    Dim layertype As CatVisLayerType
    Dim oVisProperties1 As VisPropertySet
    Dim oDocument As Document
    Dim oSelection As Selection
    Dim Status As String
    Dim index As Integer
    Dim iErr As Integer
    Dim MechPart As Part
    Dim j As Integer
    Dim body As Body
    Dim oShapes As Shapes
    Dim oShape As Shape
    Dim k As Integer
    ' Retrieve the current selection
    Set oDocument = CATIA.ActiveDocument
    Set oSelection = oDocument.Selection
    ' The work mode must be the design mode
    Set oProductRoot = CATIA.ActiveDocument.Product
    oProductRoot.applyWorkMode(DESIGN_MODE)
    CATIA.RefreshDisplay = True
    ' read the products to be colored
Msgbox "Select a product to be colored"
    sInputObjectType(0) = "Product"
    Status = oSelection.SelectElement2(sInputObjectType,"Select a product to be colored",True)
    If (Status = "Cancel") Then Exit Sub
    ' Fill a table with products selected
    iNumberSel = oSelection.Count
    If (iNumberSel = 0) then
        MsgBox "You must select 1 to N Parts to be colored.", vbCritical, "Selection"
    End If
    Redim TabSelectedProduct(oSelection.Count - 1)
    iIndexSel=0
    On Error Resume Next
    While (Err.Number = 0)
       Set oProduct = oSelection.FindObject("CATIAProduct")
       If (Err.Number = 0) Then
            Set TabSelectedProduct(iIndexSel) = oProduct
            iIndexSel =  iIndexSel+1
       End If
    Wend
    On Error Goto 0
    oSelection.Clear
    ' read the reference
     ' The user set the new color
    Msgbox "Select a reference Body For Color"
     sInputObjectType(0) = "Body"
     Status = oSelection.SelectElement2(sInputObjectType,"Select a reference Body For Color",True)
     r = CLng(0)
     g = CLng(0)
     b = CLng(0)
     Set oObject = oSelection.Item(1).Value
    Set oVisProperties1 = oSelection.VisProperties
     call oVisProperties1.GetVisibleColor (r, g, b)
     oSelection.Clear()
   ' Build the selection for new color
     'Loop on the table to put all the object on selection
     For Index = 1 to iNumberSel
         Set oProduct = TabSelectedProduct(Index - 1)
         On Error Resume next
             Set MechPart = oProduct.GetMasterShapeRepresentation(true).Part
             iErr = Err.Number
            On Error Goto 0 ' Invalidates the Resume next and clears the error
            If (iErr<>0) Then
                ' User must select part
                        MsgBox " The object " & oProduct.Name & " is not a Part.", vbCritical, "Selection"
            Else
                 iNumberBodies = MechPart.Bodies.Count
                  For j = 1 to iNumberBodies
                       Set Body = MechPart.Bodies.Item(j)
                      oSelection.Add(Body)
                      Set oShapes = Body.Shapes
                      iNumberShapes = oShapes.Count
                      For k = 1 to iNumberShapes
                          Set oShape = oShapes.Item(k)
                          oSelection.Add(oShape)
                      Next
                 Next
             End If
      Next
   ' change color
    oVisProperties1.SetVisibleColor r,g,b,0
      oSelection.Clear
      oProductRoot.Update
End Sub
And finally, default CATIA color can be obtained also like this :
CODE
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Set selection1 = productDocument1.Selection
selection1.Search "CATPrtSearch.MechanicalFeature,all"
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetRealColor 210,210,255,1
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetRealOpacity 255,1
selection1.Clear
selection1.Search "CATAsmSearch.Part,all"
selection1.Clear
Dim specsAndGeomWindow1 As Window
viewer3D1.Reframe
End Sub
Fernando
