Butt Fusion of HDPE Pipes
Hi all,
It is common for us to connect HDPE pipes by means of butt fusion. However, I found that there are different standards on fusion parameters.
For example,
DVS 2207-1
WIS 4-32-16
GIS PL2/3
ISO 21307
UNI...
Each of the above standards refer to their specific set of fusion parameters. Which one do you prefer? And why?
RE: Butt Fusion of HDPE Pipes
Use ASTM F2620. This standard gives you everything regarding HDPE fusion.
For best results as well as a warranty, you should follow the pipe manufacturer's instructions.
The standard would form a part of an overall standard that includes design, fabrication, installation and testing. You cannot cherry pick a standard to suit yourself. You have to use the whole of the suite of relevant standards otherwise you may end up with a collection of minimums.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
