Export/Import All Settings
Hi guys,
Getting a new computer at work soon and and I was wondering if there is a way to export all settings in NX. I know you can export the customer defaults, but is there something that will export stuff such as your menu locations and things like that?
Chris
Chris
RE: Export/Import All Settings
C:\Users\<username>\AppData\Local\Unigraphics Solutions\<NX version>\roles
...and it will have a file extension of .mtx and be named whatever you called your 'Role'.
Now if you haven't created any customized or personal 'Role', but have only been depending on the system starting up every morning where you left it yesterday when you logged-off, then you will need to go to...
...where you will find a file named 'user.mtx'. This file contains the current content of your menus and toolbars which you see when you run a session of NX.
Now as for the screen settings themselves, such as layout and size as well as many of the system specific preferences in User Interface, Selection, etc. these settings are stored in the system registry.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
Jon
JHTH
NX 7.5.5 + TC 8.3.2.2
C:\Documents and Settings\"user name"\Local Settings\Application Data\Unigraphics Solutions\"NX version"
The Local Settings folder may be hidden, so be careful of that.
