Export to PDF
Export to PDF
Export to PDF
When I export a drawing to PDF, the default option for text output is Polylines,  is there a way to set the default to text?  Using NX 7.5.  If so how would I do this?
KLT
RE: Export to PDF
It is in your customer defaults, under Gateway -> CGM Export
Let us know if you need tips on changing that.
RE: Export to PDF
Hi Jerry,
Can you tell me where to go.. I don't see anything on the menu bar labeled gateway.
KLT
RE: Export to PDF
File (pull-down menu)-> Utilities -> customer defaults -> Gateway (top right, click to expand) -> CGM Export (19 down from the top) -> Text mode (Change to Text) -> Apply -> OK
RE: Export to PDF
thanks!
RE: Export to PDF
(top right, click to expand) should be (top LEFT, click to expand)
