Solidworks simulation xpress error
I want to learn SimulationXpress in Solidworks, never done this before and when i try to run the simulation i get an error which say Study: Failed. It is a foundation for a small pump used in ship industry. Please tell me someone what i did wrong, as i tried different combinations and none of them will work
http ://files.e ngineering .com/getfi le.aspx?fo lder=0fb7a 05e-2852-4 ebc-a31b-7 64973bb47f f&file =pump_foun dation.rar
http: //files.en gineering. com/getfil e.aspx?fol der=780c4c 4c-606e-47 9c-a8e1-9f 8ea75a97ae &file= simulation _error.jpg
http
http:
RE: Solidworks simulation xpress error
Deepak Gupta
CSWE, CSWP, CSDA
SW 2011 SP5.0 & 2012 SP3.0
Boxer's SolidWorks™ Blog
Deepak Gupta
CSWE, CSWP, CSDA
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
But the zip file and the screen shot suggest it's a part only.
Deepak Gupta
CSWE, CSWP, CSDA
I attached the results here
Your file's link is: http
Also if someone can point me to some books or tutorials, on how to interprete the results, let`s say that a 700kg pump will rest on this foundation, it also vibrates how am i sure that the foundation is stable for the pump, i didn`t see much options in the analasys add-on maybe i`m not using the right tool. For instance in study results the base plate is bended, but normally the pump has a base plate which rests on the foundation and is tightened with screws.
Thank you in advance
I just ran the simulation and it worked fine.
Deepak Gupta
CSWE, CSWP, CSDA
Deepak Gupta
CSWE, CSWP, CSDA
