Callout Style wont apply to translated .dxf file
I am learning Solid Edge 2d for my business. I have drawings with callouts in .dft format that look just how I want. I bring the arrows down to .5 size - but for some reason, when I save the document as .dxf and open it, the callouts are in the wrong position, and just ONE of the arrows is .5 - no matter how many times I change it, it will not apply it. Any tips?
RE: Callout Style wont apply to translated .dxf file
Even creating a dxf from SE, then opening to check the translations using SE will cause minor formatting glitches.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
So this is normal? When someone opens it in AutoCAD will they view it properly?
I've had similar problems opening dxf made by other systems.
What product suite are you using for saving Adobe pdf images?
Ken G.
http://grundey.blogspot.com
