pitot tube pump ??
pitot tube pump ??
L.S.,
I was a bit surprised learning about the existence of a pitot tube pump. It might even be a worthy adversary of a side channel pump, as I have been told. Can anybody enlighten me about the pros and the contras of a pitot tube pump as I cannot find it in the literature available to me? Reason for my question is that I am considering this pump as an alternative for a current side channel pump. The side channel pump seems to be very sensitive to abrasive particles (<0.2mm). These are present in our condensate system, where the side channel pump is active.
I am gratefull for any hints or experiences with pitot tube pumps.
Karel Postulart, The Netherlands
Nuon Power Generation
RE: pitot tube pump ??
• High pressure without high speed.
• Efficiency at low flows
• Able to pump non-lubricating fluids
• Large differential head in a single stage
ht
h
Please let me know if I can help you in any way.
Due to your message I search the internet but I couldn't find any pitot pumps at Ruhrpumpen. Maybe you can send me a set of data sheets about your pitot pumps?
Out Combitube Pump (Pitot Pump) is our of the latest products we have cam eout with, I believe we introduced it in Oct.2011.
Hence the reason it is not on our website yet, as many other pumps we have as well.
However I have attached a couple of brochures on the pump.
Please feel free to contact me if I can be of any further assistance.
Dan Waddell
National Sales Manager
Ruhrpumpen, Inc.
Cell (530)517-0142
dwaddell@ruhrpumpen.com
Absolutely, please feel free to contact them.
I am sure they will be able to help you.
If you need anything else feel free to contact me as well.
Good Luck
I am very familiar with this pump and would be happy to answer your questions. In full disclosure my company has been manufacutering pitot tube pumps for over 50 years. You can find us at http://www.weirpowerindustrial.com/products/roto-jet_pump.aspx
Yes any grit in the working fluid will give you issues with any pitot tube pump. The head is developed by forcing the fluid at high velocity into a pitot tube. Any particlutes can erode the tube. The pump can handle some at a increased wear. The pitot tube will have to be replaced more often...so if it is possible to use the pitot tube pump in your application will depend on the amount of particulate present and your tolerance to periodically changing a pitot tube.
We do have sales representation in the Netherlands
Feel free to contact me if you have any questions
