Difference between "must cost" and "must have cost"
Hi there,
I've been trying 2 figure out the difference between "must have cost" and "must cost" in this example:
Jenny's engagement ring is enormous! It must have cost a fortune.
the sentence was taken from a modal verbs test: (http: //www.engl ishpage.co m/modals/i nteractive modal8.htm). According to the solution, the correct answer is "must have cost".
I feel that this is the only right option, but cannot find any grammatical arguments for it.
Anybody? Please help.
RE: Difference between "must cost" and "must have cost"
"...must cost a fortune." This is present tense, describing what its imagined cost is now.
Before, the cost was what the jeweler sold it for. Now, the cost is dependent on the bride-elect's level of happiness with her situation. If her fiance is her true Prince Charming, she may consider it to be priceless. If she later finds him to be a philanderer, it may cost much less.
"must have cost" is speculative. If the cost were known, the observer might have said, "Jenny's engagement ring cost a fortune." Or she might have said, "Jenny's engagement ring did cost a fortune."
A piece of advice for you, pyrszel. I advise against texting abbreviations in the forums. "I've been trying 2 figure..." does not give the reader a good impression of the writer.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
i don't know how you would use "must cost", even in present tense. "it cost a fortune" is clearly acceptable (for Jenny or her betrothed to say/boast).
That being said, if you spent the fortune, then you don't have it either... just the ring.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Don't quite agree that "must cost" would always suggest that something has not yet happened, eg, it must cost a fortune to cruise on the QE2.
I suspect that if one had already paid for the cruise, one would not say what it must cost, but rather what it did cost. The person who is saying what it "must cost" is not likely to have already made the purchase.
Good Luck
That's if they intend to purchase a ticket - maybe just passing comment, therefore "it must cost a fortune to cruise on the QE2." is a statement without any real time reference.
I don't think intent is any way a factor; either a purchase has taken place or a purchase that has not happened.
"Must have cost" refers to a purchase in the past tense, i.e., a purchase that has already taken place, and the speaker is speculating as to its cost. "Must cost" is a present tense phrase referring to a purchase that has not taken place with the speaker speculating about the cost.
Good Luck
