Entrainer for THF/Water distillation
I am looking for an entrainer to separate THF and water. I am aware that Pentane is used in certain applications however we are looking for an alternative entrainer. Any suggestions?
RE: Entrainer for THF/Water distillation
minimal (say less than 10%) or are they about
the same? Do you want to recover the water or can it be wasted? If mixture is mostly THF then passing it through salt (NaCl) will make a THF layer that is about
2.5% water (The bottom layer is salt water.)
I suppose you mean that pentane would entrain
THF in the top layer of a decanter. I have experience using toluene (more toxic than pentane however).
I would imagine that THF would prefer many organics over water.
One technical book says that THF and water form an azeotrope with composition sensitive to pressure. So they can be effectively separated in a two-stripping column system operating at two pressures: the atmospheric, taking water as a bottom product using stripping steam as heating medium. The condensed overhead stream from this tower, serves part as reflux, the remainder is sent to the middle section of a pressure tower heated with a reboiler. The bottom stream of this column is pure THF, the top stream is condensed. Part of it is used as reflux and part re-sent to the original blend of THF and water. The pressure tower works at about 7.5 atm.
Although not exactly satisfying your request, I hope this message helps.
90% (10% Water) can be reached with a simple distillation. The dehydration from 90% up to 99.5% is easy by pervaporation.
a general info is available under:
www.sulzerchemtech.ch/eprise/SulzerChemtech/ Sites/products_services/pervap.html
Feel free to ask for more info or sizing details.
pierre.strauch@sulzer.com
