Hilti Under Cut Anchors For Underhung Crane
A runway was installed for a 5 ton underhung crane. It is suspended from a concrete ceiling with embedded headed anchors. Due to a screw- up a pair of support locations failed to be installed. I work for the crane installer. The customer's engineer has suggested Hilti undercut anchors. I have looked at the Hilti specs and am aware that it is suitable for fatigue applications. I am aware of how these replaced the failed epoxy anchors at the Boston dig.
I am not comfortable in using these anchors for suspended crane loads. I would appreciate to hear about experience with this type of application.
RE: Hilti Under Cut Anchors For Underhung Crane
Dik
100 % inspection and proof testing can reduce a lot of speculation.
Immediately after the Big Dig failure, Hilti came out explaining that their products were not involved and that their products were creep resistant.
Dik
Michael.
Timing has a lot to do with the outcome of a rain dance.
Follow Hilti's instructions.
