Support ER for the ability to sort/reorder Ref sets
Call GTAC and reference ER 6706564 if you would like to have the ability to sort/reorder added reference sets...currently you have to add them in the order you want = not cool if you have a large list
RE: Support ER for the ability to sort/reorder Ref sets
Why are you using so many reference sets? Maybe you should be using arrangements instead. Refernce sets are to filter what is seen at the next higher assembly level.
Explain how you are using reference sets and what real advantage there is in having them sorted.
Ben Loosli
We actually do use arrangements in combo with reference sets. Its a lengthy explanation (and didn't mention because I figured others would have other reasons)but overall...
My company uses Teamcenter with a release system (so we're rev controlled)
we manufacture parts and we have operations that we release individually. They have individual operation sheets. On the sheets we show the blueprint (finished product) in phantom within the current operation to show how much stock we have left (but not on every op sheet) So will all this in mind we have come up with a particular scheme that works. (This is the second iteration. the first worked off of pure wavelinks from one op to the next, but messed up when earlier ops needed to be revised [note we don't have the extra wave lic..just the one that comes with modeling])
We create a blueprint model (finished product)
We create a starter model (like a casting,forging etc)
We create a process model. This is where all the magic happens
We create individual op files (pretty much the same exact thing but with different ref sets...u will see)
The process model contains the starter and finished model and a bunch of preset feature groups for each op.
We create arrangements that allows us to suppress both (or just the starter). we wave link in the starter model and start our first op. The following op's are extracted bodies.
For EACH OP WE CREATE A REF SET of the wave/extracted bodies, and some jobs can have a ton of op's (and new one can be added when the whole process gets Rev'd).
(you may wonder why but its easier to create a bunch of ref sets in one model rather than creating just a handful of ref sets in tons of models...)
Each individual op is created is separately as an assembly with the process model at a particular ref set (the one of its op) and arrangement (depending whether or not we want to show the finished model in phantom).
So..... over all if we have a lot of operations for a particular job we can have a lot of reference sets that we can not sort/reorder. If I have to add an op in the beginning and the process model has a ton of op's then I'm stuck with it on the bottom = not cool!
Imagine jklajjsijnl6kee0eewp8778fa7987 compared to 12345abcd
As a side note, what would work out even better than being able to sort/reorder ref-sets would be to be able to select a time stamp to show the model at when drafting/applying view (I heard other software allows for this) This way I wouldn't have to deal with a ton of extracted bodies and a ton of ref-sets. I just figured that was less likely to happen then just enabling the up/down arrow for the ref/sets.
