Structural question
Structural question
Dear All,
is there any problem of designing two way slab having thickness 8 inches though other adjacent slab thickness are 6" and 5"?
what kind of consideration i will take while performing the slab design?
Thank you.
Engr. Faisal
Thank you.
Engr. Faisal
RE: Structural question
RAM Concept is one application that makes the design of such slabs easy.
Different question, Mike... maybe same project.
Dik
If you were dealing eith a major haunch though, bending the rebar through the haunch, you might have to install radial tension bars at the link to keep the rebar from wanting to pop out of the slab.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
thnx dik i will take care of the formwork.. .
@ mike nope its a different project with different problems.
