Elevated concrete slabs on metal deck
Hi.
Subject: 4 and 6 inch thick normal weight concrete slabs with B-Lok type composite deck setting on bar joists or WF shapes without shear studs. Reinforcing not yet designed.
I've done several of these, but they were always small, single pours. I'm now tasked with designing a large-area slab. Where can I find construction joint details and sawcut placement guidelines...if they are different than slabs on grade.
Thanks.
Thanks.
RE: Elevated concrete slabs on metal deck
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
http:/
htt
h
Also look in AISC Design Guide 18. They have some details.
It's no trick to get the answers when you have all the data. The trick is to get the answers when you only have half the data and half that is wrong and you don't know which half - LORD KELVIN
And, Hokie- gottit. I'm up to speed now.
