Low alloy steel (F2v) material magnetic particle NDE testing
Hi ,
Could you please advice is there any problem occur in F22v alloy if it went for magnetic particle testing?
RE: Low alloy steel (F2v) material magnetic particle NDE testing
the process is as follows.
1) std f22v
2) test NDE( magnetic particle )
3) heat treatment (+1200 deg C ( austenitic temp ) for increase mechanical properties.
4)forging to required shape
5)weld overlay by Ni alloy .
6) NDE (magnetic)
So my concerns is if I conduct magnetic NDE before heat treatment and also before weld overlay, the Fe particles using for NDE could affect the alloy.
