UDE instance in ADAMS
Hello.. Does anyone know what are UDE instances in ANSA and their purpose??
For example, if I create a General Motion on a joint it will appear in database browser under the MOTIONS. owever, if I select from screen a revolute joint>press modify and then press impose motion, the motion will appear under the ALL Other/UDE instances list .. So what is the difference??
Whats the different between these two kinds of motions??
Thanks for your help
RE: UDE instance in ADAMS
Cheers
Greg Locock
Why are you asking here rather than on the MSC support forums?
Create a simple model using each way of doing it and then export the adm code for each one. Comparison of the adm files will probably reveal a difference in numbering schemata, but no difference in functionality.
Cheers
Greg Locock
