Nozzle/Branch pipe sizing
Hi all, I'm quite new to piping engineering, and I've been tasked to  determine the sizing/diameter of a branch pipe for a reducing tee junction.
Are there any equations that I can use to compute this?
I've seen some of the ASME B31.3/31.4 and I am not sure as how it is governed. for example, the use of the header-branch diameter ratio.
Thanks all in advance.
RE: Nozzle/Branch pipe sizing
Theoretically you should start with a required flowrate and the available pressure drop to work with to get the branch diameter, or it becomes a purely mechanical exercise in which you could pick virtually any smaller, or even equal, diameter as the mainline.  Generally you can use a stock T for diameters down to 1/3 the mainline diameter.  Below that, probably branching from a weld-o-let would be more suitable.
What would you be doing, if you knew that you could not fail?
do you have any idea for reference that i could use to obtain the flowrate/pressure drop process?
Probably a million on a slow day.
Gas or liquid line?
Google the D'arcy or Darcy equation, or the Churchill equation to get the pressure drop in a pipe running full.  Churchill is easiest, no iterations needed to determine friction factor.
ok i managed to go to the library and dig out a book "Flow of fluids through valve,fittings and pipe".
They gave the an equation for flow of fluid through nozzle and orifices. There is a diameter term inside, so I'll just use it to compute?
No, that's for flow out of a tank nozzle, across an orifice, or something.  You will find that you lack certain information for some of those variables and you won't be able to solve directly.  You have a pipe with a pressure drop that will establish the flow rate for a given diameter.
oh, so u mean i need to compute the pressure drop first? how do i find the pressure drop for a reducing tee?
you need the pressure difference between 1) the pressure in the mainline at the point where you will place the tee and 2) the pressure at the end of the new branch at wherever it will tie in.
i see, so using the pressure difference, i can find the diameter of the branch pipe
YES! If you know what flowrate you want.  Otherwise you can assume a diameter and see what flowrate that diameter gives you with your given pressure drop.
PantheraX
You could download the freeware from this site and model the branches with different flow rates and compare the losses.
http://www.pumpsystemsmatter.org/content_detail.aspx?id=110
If you get to engineer systems of greater complexity you could invest in AFTs athom for steady state Impulse for dynamic analysis. The PSIM software is a cut down version of Fathom
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
PantheraX
In PSIM sotware the complex tee cannot be defined directly.  However the pipes that are conencted to a tee can have a tee's losses defined.
Once drawn select the pipe and go to Fittings and Losses. Then select  "Others" go to tees in the drop down menu. There you can add a tees loss, whether straight through or branch, to the pipe losses.
You could draw a system then copy and paste so two ssytems are on the workspace. One could be with losses and one without and you can see the differences.
Pipes could be kept short so losses in fittings mean more than straight pipe.
Please let him learn how to do it a little bit before you change him from an engineer into a software operator.
thank you so much BigInch and stanier!
will do the manual calculations for this first and attempt the software in awhile!
thanks again guys.
Good plan.  I think you have to at least get enough experience to be sure you can spot a garbage in - garbage out problem before you go pushing the buttons.
Biginch is right, again. I got ahead of myself. Learn the basics before using a tool that automates what you are doing.
The AFT manual actually says all results should be checked by basic hand calculations. Sound advice indeed.
I you are member of a professional isntitution such as ASME, IMechE or Engineers Australia you will find that they have access to electronic libraries such as Knovel. there are numerous books on facilities piping that have the data you need to study.
The Crane reference is a classic as are books by Miller (Internal Flow Systems) and Idelchik.
http://www.pumpfundamentals.com/images/tutorial/friction%20loss-fitting.pdf
http://www.accutech2000.com.au/FluidFlow3/Support/Modelling%20and%20Design%20Notes/Modelling%20and%20Design%20Note%2002%20%20Tees%20and%20Wyes.pdf
http://books.google.com.au/books?id=5elAVCubfyoC&pg=PA1117&lpg=PA1117&dq=fittings+idelchik+loss&source=bl&ots=go7TQ97h0K&sig=zy_lgSbI6as5rB-b36n4Wc63qXk&;hl=en&;sa=X&ei=qDybT8HeN8eviQe97sjQDg&ved=0CDYQ6AEwAQ#v=onepage&q=fittings%20idelchik%20loss&f=false
hi guys, i've been trying the manual calculations and could i ask, in the equation of headloss (HL) = K(v^2)/2g, where does this headloss represent? between the start of the run pipe to the end of the run pipe? how do i then find the head loss between the section of the branch pipe?
and also, for the division of flow for tee fitting, could i just use the ratio of areas to compute?
let me try to answer my own question, correct me if im wrong guys.
1) the headloss equation for fittings, HL = K(v^2)/2g is for the head loss through the section of the branch pipe.
2) Division of flow for tee fitting, i'm supposed to use ratio of pressure drops. I've read that for reducing tee, flow split ratio may not be equal to ratio of areas.
K(v^2)/2g is not the D'arcy (or Darcy) equation, or the Churchill equation
hmm, but i came across it in some piping articles that suggested using the K (obtainable from Miller chart) instead of f(L/d) to obtained additional losses due to fittings such as that of tees. Am I not supposed to do that?
Also, your emphasis on knowing the flow rate for my design is that the velocity would be required, is that right?
Don't do that.  K values are for calculating pressure drops at relatively short valves and fittings.
Three primary variables are,
Flow
Inlet pressure
Outlet pressure
knowing 2 of those, you can calculate the one missing variable.
Flow divided by pipe area = velocity
ok i understand, since K is just a modification of the f(L/D) term. Better to go back to basics.
But now i'm stuck with a problem, how do I calculate pressure of a point in a flowing pipeline?
It has static and dynamic pressure components?
Say, for an underground buried pipe?
That is derived beginning with the Bernoulli equation, include a head loss coefficient (based on D'arcy's method, or some other one) for friction due to the flow between any two points.  With Bernoulli, if you know the energy at one point, you should be able to calculate the energy at another point.
Since two of the three variables I gave you above are pressure and you must know two of the three, at least one known variable must be a pressure.
If you know the upstream pressure, you can calculate downstream pressure, or visa versa.  If you know both pressures, calculate the flow.
ok. I understand it now.
Thank  you so much BigInch. I felt i have gained a lot from your comments. Thanks stanier as well.
Good. You're off on the right track then.
Come back when you have more questions.
Ok, I have managed to create an Excel template to help me compute.
BigInch, do you know of any pressure drop limits for large diameter pipelines? It seems like my pressure drop value is quite small though.
What's your pipeline diameter, length and the product inside?  Gas or liquid?  Some pipelines can have flow friction losses of up to 10 psi/mile, especially if pump power costs are low.  Once an initial pipeline diameter has been found, usually based on liquid velocities of 3 to 10 fps, a potential increase in that diameter can be seen worthwhile if pumping costs drop at least as much as the cost of the larger pipe diameter plus the supposed construction cost increment.  Most of my pipelines seem to fall into 50 to 100 mile distances between pump stations, depending on products, water, diesel, gasoline, kerosene, natural gas, etc. and, if a liquid product on the topography of the pipeline (elevation profile).  Pumping over hills or a mountain range will roughly shorten the distance between stations by the static pressure of the change in elevation / psi per mile pressure loss.
my pipeline diameter (run diameter) is about 7ft, run length about 5ft , branch diameter is  4ft with the branch length of 2ft and it carries water (liquid). My initial pressure at inlet is 230psi and a relatively slow flow of 1.6 fps.
Based on what I calculated, it seems the pressure loss over the length of branch pipe is around 0.07psi.
I'm not quite sure if such a small value of pressure loss would be practical as I have no dealt with such pressure loss calculations thus far.
Would your experience justify such a value for the above mentioned dimensions?
It's probably correct for the pipe. The pressure drop with normal flowrates for pipes that short would be less than the pressure loss of fluid exiting the Tee fitting where they start.  The Tee losses are probably 15-20 x the loss of a foot of branch piping.
If you have a 1.6 fps velocity the size is OK.  The trick may be holding enough backpressure in the downstream connection to keep the branch pressure near the 229.93 something psi that you will need to keep your actually developed flowrate hanging around that calculated value.  Without sufficient backpressure at the branch outlet in the downstream pipeline, flow in the branch will tend to accelerate.  You need to verify that the downstream pipe pressure at that point is nearly 230 psig, or try to live with the increased flowrate, if it is lower, or for that matter, the decreased flowrate, or backflow, if it should be higher. If it's backflow, put in a check valve to stop backflow when the pressure is high.  If the downstream pipe has a very low pressure, you will need to install a backpressure control valve on the branch to keep the flow from increasing.
"my pipeline diameter (run diameter) is about 7ft, run length about 5ft , branch diameter is  4ft with the branch length of 2ft and it carries water (liquid). My initial pressure at inlet is 230psi and a relatively slow flow of 1.6 fps."
7 ft diameter x 5 ft run, branch = 4 ft dia x 2 ft run?
That describes a single Tee fitting, not a pipeline.  What are the lengths of the whole assembled run?
If your objective is to treat the fitting in isolation and assume that the delivery pressure at the end of the branch pipeline is the same as the delivery pressure at the end of the main run pipeline (thus equating the dP in the run and branch downstream of the tee), then I think your flow split will end up being:
(Qb/Qr) = [(Lr/Lb)*(Db/Dr)^5]^0.5
I apologize if I got that wrong and made myself look like a fool.
