pump curve
pump curve
hello all,
just wondering if anyone has the following pump curve:
PUmp: worthington
Model:6LR-13A
Rpm: 1475
kW: 30
thanks,
PUmp: worthington
Model:6LR-13A
Rpm: 1475
kW: 30
thanks,
RE: pump curve
What would you be doing, if you knew that you could not fail?
RE: pump curve
i'll be happy with a good approximate.
its an old pump in the turbine room and unsurpringly the pump curve is nowhere to be found in our system.
RE: pump curve
BEP flow? head?
RE: pump curve
http
the curve is at 1175 RPM but you can scale it using the affinity laws
RE: pump curve
RE: pump curve
RE: pump curve
nothing else is available from the nameplate. How would you have contructed it anyway?
RE: pump curve
RE: pump curve
Thanks a lot for being a search whiz.
The curve u provided will do.
RE: pump curve
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
RE: pump curve
The 1170rpm curve is all you need to redraw a 1480rpm curve to give you accurate information, if you need assistance please ask - we can guide you in how to do it.
RE: pump curve
I will use affinity laws to change the data points (head) to suit 1480 RPM.
