Seismic Bracing at Extended Lengths
I have a retrofit project that requires seismic bracing. The unique situation here is that the concrete structure is 18 feet above the ceiling. If possible, I want to prevent running the main and lines up high.
I'm not sure as to the best way to brace this system when the pipe is installed near the existing ceiling. When we use the cable restraints for the branchlines, the cables will have to be so long that there will be considerable sag in the cable. If the cable is pulled tight at those long lengths, it picks the pipe up out of the hangers.
The rigid bracing on the mains could easily exceed 25 feet in length. Obviously, this presents it's own set of problems.
Has anyone encountered this before, or know of a possible solution?? We must maintain a UL listing and FM approval on the final assembly.
Thanks in advance.
Thanks in advance.
RE: Seismic Bracing at Extended Lengths
Good luck on the project.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
I cant help but think about the long drops though. During a seismic event, wouldn't this become an issue??
Travis Mack
MFP Design, LLC
www.mfpdesign.com
