Associative Note with Geometry Parameter
Is there a way in NX 7.5 Drafting to have a note that is associated with a dimension or parameter of a 3D geometry?
Example: We have a huge plate with many square pockets. The floor thickness of each pocket varies; instead of making many cross sections in the Drafting module to show the floor thicknesses, we were wondering if on the top view, we could add "associative notes" inside each pocket which would be associated with the pocket floor thickness.
If so, how could this be done? If not, any other suggestions?
Thanks in advance!
Thanks in advance!
RE: Associative Note with Geometry Parameter
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
