ANSYS Workbench 13 Results Legend
Folks,
ANSYS Workbench 13, Static Structural analysis, In Solution Menu, While Viewing at results, Von Mises plot
When I right click the contour plot color scale/legend, I get a drop-down list and the list has option called, "Adjust to Visible".
My question is, "What does the option of "Adjust to Visible" do to my von-mises plot?"
Please refer the attached link for the screen shot.
Thanks in Advance.
RE: ANSYS Workbench 13 Results Legend
ANYBODY HERE CAN ANSWER THIS PLEASE???
It updates the legend for the plot you see on screen.
For example, if you change the "Display Time" on Solution "definition" property and retrieve the results, the plot will be updated but the the legend won't change for itself, so you'll need to do the "Adjust to Visible" in order to update it.
