we have problem with alum sludge, p
we have problem with alum sludge, produced from enhanced coagulation of water. sludge is discharged to Wastewater treatment plant, it is causing odor and some other problems in Wastewater treatment plant operation.
If any one have experiance with this problem please help me.
RE: we have problem with alum sludge, p
Please give us a bit more infor if you can...
Bob PE
> Did you just start discharging to WWTP? Process may be adapting, but I agree with other responder that it may improve process (but, see below).
> EnCoag may be removing more organics, or supressing treatment pH, which may make it more susceptible to going anaerobic during conveyance to WWTP.
> With EnCoag, did you change coagulants?
> Do you batch discharge, or is it on a regular basis? If you're sending a big dose on a night shift when other contributing flows are low, you could be overloading WWTP.
Give me a call if you want to discuss further
814-867-1477 or e-mail, jdewolfe@mcguireinc.com
You may consider these two issues:
1. Instead of discharing the sludge to the WWTP, use centrifudges/presses or similar to dry it and dump for landfills.
2. Dilute the alum sludge before discharging to the WWTP, so that the amount of alum sludge will not be too significant compare with the inflow of sewage. The amount of dilution will be mainly based on the process of the WWTP.
Hope these can help
What is it's detail chemical analysis? Alumina? Sodium? Potassium? etc.
