Wind load Parabolic antenna
hi,
I try to calculate the Wind load on a parabolic antenna with ASCE 7.6-05 . I want to consider the worst case of the antenna but I am not sure which influence the shape of the antenna has. Can i just say that the antenna is flat?
sincerely,
Marcus
sincerely,
Marcus
RE: Wind load Parabolic antenna
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
If you are looking for wind loads for parabolic or conical or grid type, Go to "Andrew Antenna" website and download their wind calculator.
It will give you all the worst wind loading values and direction for the antenna.
