Seismic Accelerations - IBC & ASCE
Hi All,
Can someone please advise what is the acceleration values used when designing steel structures using IBC or ASCE codes?
1. What values are commonly used?
2. What are the maximum/worst case values?
Thanks in advance.
SubseaOcean
Thanks in advance.
SubseaOcean
RE: Seismic Accelerations - IBC & ASCE
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
M^2.. I don't think 0 is a real possibility, as there is always some level of seismicity. Also, I've never seen it, but from a purely theoretical standpoint, I don't know why 1 would be an upper limit.
Appreciate everybody's comments. I went to the link, which gives a good table of accelrations.
htt
The accelerations values range from 0.0017 to more than 1.24.
SO
Get a structural engineer. You cannot do seismic design without any experience AND formation background.
