Sharp Corners in CIP Retaining Walls
I cannot find anything in ACI-318 or 350 that addresses the additional reinforcement requirements at a corner in a retaining wall, unless I overlooked it. I know it is common practice to put additional horizontal bent bars or hairpins at the corners. Is there anywhere in the code that addresses this.
By the way, I am dealing with cantilever retaining walls that hold back soil and also tank walls.
Thanks for your help,
Donald
Donald
RE: Sharp Corners in CIP Retaining Walls
Or is it an external corner where the loads are pushing the orthogonal walls together?
In either case, dcarr is correct to analyze the wall's horizontal moments and design accordingly. In the case of the re-entrant corner, you also have to look at shear-friction through the wall and provide tensile rebar as well.
It's no trick to get the answers when you have all the data. The trick is to get the answers when you only have half the data and half that is wrong and you don't know which half - LORD KELVIN
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
