Honeycomb : problem with defining boundary conditions
Hi, I am quite a novice in Abaqus and working on a honeycomb project.
I obtained my full assembly by duplicating the initial pattern and then constrained it using edges and points coincidences.
The problem is : I am supposed to encastre one face of the sample, and to impose a vertical deplacement on the other side (it is a compression test)
Thus, I must apply the boundary on all the edges of each honeycomb cells, what will be veryyyy long... Isn't it a more clever solution to work properly with my honeycomb sample ?
I tried to put some rigid sheet on both sides of the honeycomb cells, but I can't define the boundary conditions directly of theses sheets...
Thanks you in advance, and sorry if the description of my problem is not very clear, I am french and not very used to use technical vocabulary !
Here are two screenshots of my sample, with and without the additionnal rigid sheets.
without :
htt p://images hack.us/ph oto/my-ima ges/338/sc reennr.jpg
with :
h ttp://img1 8.imagesha ck.us/img1 8/3497/scr een2ry.jpg
without :
htt
with :
h
RE: Honeycomb : problem with defining boundary conditions
For your rigid plates you need to apply the constraints to a reference point that is tied to the plates.
I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
