Strength of old truss plates
Trying to evaluate the resistance values of truss plates in a residential roof built in the 1960's. There are two teeth per an area of approximately 1in x 1.5in. Teeth approx 5/8inch deep. 18gage plates. Can't find any values for this plate. Would using the resistance values of current Mitek plates be acceptable?
RE: Strength of old truss plates
Look carefully at the plate - you might find a name - but I doubt it - most of us tried to "hide" back then!!
Here is a short? list of some of the plates in the 1960's
Anchor Lock, Anchor Lock of Florida
Dura-Plate, Duralite of Ohio, Inc.
Trusset Plate, Empire Roof Trusses
Gang-Nail, Gang-Nail Sales Co.
H-Brace, H-Brace, Inc.
Hydro-Nail, Hydro Air Engineering
Hercules Truss Plate, International Truss Plate
Penhurst Connector, Penhurst Machine Co.
Ronel Barbgrip, Ronel Corporation
Sanford Gri-P-late, Sanford Truss, Inc.
Templin Truss-Lock, Templin Associates
Tim-Plate, Timber Fabrication
Gismo Gusset, Truss Prefab, Inc.
Truss-O-Matic, Truss-O-Matic, Inc.
Tru-Raf, Truss Connectors of America, Inc.
Not sure how you would go about finding the plate you have and its original values.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Newer designs often exceed 200 psi
With 5/8" embedment, the capacity is likely higher, but that depends also on tooth density.
Most truss plate capacities are empirical anyway, so you'll need some tables from the mfr. Search as others have noted.
