Help wiring a Bodine 1 phase 115VAC motor
I have a Bodine ECI-58E2 motor that I'm not sure on how to wire up. It has 1 red, 1 white, 1 green, and 2 blue wires coming from it. Both the blue wires go straight to the capacitor. Looking from the front, the capicitor does have a red mark on the left lead that you can see in the picture. The motor came with the two blue wires connected as they are. Not sure if they are supposed to be like that or not.
I would like to be able to wire it with either a double poll switch or two individual switches; one for forward and one for reverse.
Thanks in advance for any help.
RE: Help wiring a Bodine 1 phase 115VAC motor
verify with ohm meter cont between red & white then check green to case
http://www.bodine-electric.com/Tools/Handbook.asp
Mike Halloran
Pembroke Pines, FL, USA
Model number ECI-58E2 is not in our product database. Please try another model number.
If you need further assistance, please contact our customer service team: info@bodine-electric.com
Hint: Specify a 4-digit stock model number from our catalog. If you're looking for a non-stock model, precede the model number with an "N". Example model numbers: 0648, 3836, N4800.
You can also specify the serial number from the motor's nameplate.
Probably not. (NO)
Bill
"Why not the best?"
Jimmy Carter
BTW, you were right, green is ground, white neutral, and red power. Works great. Thanks everybody for the assistance. Cheers!
