Which pile type is best to use in overconsolidated silty clay?
Which pile type is best to use in overconsolidated silty clay? example London clay?
Driven, Bored or CDA piles? (No water table is evident in tests)
RE: Which pile type is best to use in overconsolidated silty clay?
Regarding stone columns, their construction in this type of clay will require pre-drilling. The load capacity of a stone columns is about 25 tons, it might not be sufficient to replace piles even if you go for a raft.
