Hollow portion in a solid
Hello ,
I have created a solid body and in that part,inside some solid has been cut.This makes the main solid hollow from inside at some particular area which is invisible from outside.
If I make the part in wire frame and see ,it can be seen.
But what about some minor hollow objects which may be present in the big parts like IP,Head liner etc.
So my question is,whether it is possible to show hollow portions present in a body ?
For better clarification I have attached an image please have a look.
Ravindra.R.Udandakar
Mob:-+91 9960608414
RE: Hollow portion in a solid
You can edit the color of the faces inside the hollow.
Edit->Object Display (pull-down)->Type, only "Face" is highlighted->OK->selct faces->OK->select color and change to what you want->OK
Mob:-+91 9960608414
If it's at least NX 5.0 you should be able to use Check Mate, by going to...
Analysis -> Check Mate -> Tests -> SASIG-PDQ -> Solids (G-SO) -> Solid void: G-SO-VO
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
