Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Really appreciate your site. Really good site for learning what others do when they run into problems. You guy's are great!!!..."
Geography
David09281971 (Civil/Environmental)
24 Apr 12 9:23
We have poured a concrete slab that has minor cracking in it. The builder wants us to pull slab and replace it. The only spec that is called out is to replace if there is excessive cracking. I am trying to find any information i can to stop us from removing and replacing. I have looked thru ACI documents and could find nothing when it comes to slab on grade.
JAE (Structural)
24 Apr 12 9:37
This thread is similar and has a bit of info:
thread194-286107: Concrete Crack Acceptability Guidance
dik (Structural)
24 Apr 12 10:32
You are a sub-trade to the builder?  What type of slab?  slump? sawcuts? when? size? thickness? weather during pour? curing? anything specified?
Lots of questions...
Dik
hokie66 (Structural)
24 Apr 12 18:07
Whose design was it?  Were the placement and curing specifications adhered to?  What is the useage of the slab?
asixth (Structural)
29 Apr 12 3:41
What is your definition of minor cracking in terms of crack widths. I think the crack widths in the thread attached above are for flexural cracking limits (please advise if I am wrong).
I recently had a slab on grade experience cracking at re-entrant corners of 2mm after 1 week and will continue to widen. This was a result of saw-cutting too late (the foreman called me and told me he wasn't going to sawcut until the following day which hopefully relieves me of some indemnity) and not placing #4 trimmer bars at the re-entrant corners (they probably try and put the indemnity on me for not picking up on that during inspection).
Close Box
Join Eng-Tips® Today!
Join Us             Close
