keep constraints when changing assembly
Imagine the following situation:
assy1:
part1
part2
part3
subassy1
which I want to turn in:
assy 1:
subassy 1
part1
part2
part3
Now, drag/dropping part 1-part 3 from assy 1 to subassy 1 will give me this. But is it possible to keep the constraints between them intact? Since the constraints are between the to part and don't really have anything to do with what assembly they are in, I don't see why this wouldn't be possible.
Thanks in advance.
P.S.: You could save assy1 as subassy 1 and import it in assy 1, but I'm looking for a less tedious way. Since the above will cause problems when not being careful because of teamcenter integration.
assy1:
part1
part2
part3
subassy1
assy 1:
subassy 1
part1
part2
part3
Thanks in advance.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: keep constraints when changing assembly
Add an Enhanced Request.
This is possible because new assembly constraints doesn't have parent link.
Thank you...
Using NX 8 and TC8.3
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Help -> Online Technical Support -> Log an Incident with Technical Support
...and if you describe what you're submitting as being an Enhancement Report, it will logged in that manner and you will be notified of the ER number which has been assigned to it. If and when any action if taken on your request, you will receive subsequent notification to that effect.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
