Crystal Surface
Crystal Surface
Crystal Surface
I was wondering if anyone had any bright ideas for rendering a crystalline surface on a part. My company is making some cradles for amethyst rocks, and I'd like the SW models in the cutsheets to have something more resembling the actual item than "an extruded spline loop with one purple face." Simple solutions (i.e. not a 3D sketch with fifty vertices) would be appreciated.
-Josh
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
RE: Crystal Surface
Perhaps you could save it as a .stl file, then import it back into SolidWorks. The .stl file will be facetted instead of a smooth surface.
Joe
SW Premium 2012 SP1.0
Dell T3500 Xeon W3505 2.4Ghz
6.0GB  Win7 Pro x64
ATI FirePro V5800
RE: Crystal Surface
Sorry, to clarify: I want to fake-model a complex, crystalline surface. I'm going to be using a front/side view in the cutsheet for the part, so a decal (while better than what I have now) isn't quite what I'm looking for.
-Josh
RE: Crystal Surface
I would try using a Polygon sketch (8-sided), extrude that with a draft to create a point, then Fill Pattern.  You could probably do various sizes and heights to get a quasi-irregular look.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Crystal Surface
Succinct summary of the situation. I've thought of faking a row of crystal-looking profiles, then screwing around with linear/circular patterns bounded by the wall of the piece, but that seems like a nightmare waiting to happen. I was hoping someone could think of something brilliant that I wasn't seeing.
