cold warping of glass
Cold warping of glass has been a trend in building envelope design and it interests me to do a research on this. Any good references, standards, codes, etc. you can recommend? Aside from the effect on glass, sealant design is also of concern. Thanks!
RE: cold warping of glass
this site could be properly used to get opinions on references ... "is XYZ a good reference ?", "i've read different things about ABC ..."
Thanks much for the info., you would think this was your research project. Talk about an expensive and complicated project, all to salve an architect's over inflated and bent out of shape ego. All the article talks about is that the almost impossible can be done, if a client is willing to throw enough time and money at it. With today's computers and software that geometry and analysis can certainly be handled, but at what cost per sq.ft.? Not one conc. form could likely be reused, no two (or damn few) pieces of anything were a repeat, including rebars in a given column. There probably were some .75" bolts of the same length on the job. They could have had twice as much usable bldg. space, and a good looking bldg. too, if they had hired and architect and structural engineer instead of someone who fancies himself and artist/sculptor. I grant that glass will flex as they have made it do in its aluminum frames, and I take my hat off to the glass fabricator for their study and analysis on the matter. But, it will be interesting to see how those glass panels start popping out under significant lateral loads or after 15 years of environmental degradation, given that they are starting out with all their elastic flexibility used up for arts sake.
Talk about a waste of everyone's time and resources. I'll bet those turkeys tried for a Platinum LEED rating too, all that fly ash and hot air used up in one bldg.. And, only one man's opinion, but the bldg. isn't particularly attractive either, just very complex and difficult for complexity's sake. Wait until they start furnishing that place, all of the furniture and fixtures will have to be specially made to fit the curved and sloping walls. But, it's a Frank Gehry building. We have one in our town, all you have to say is 'the crushed pop can' and people know just what you're talking about.
Structural is certainly not my area of expertise (if any), but I tend to agree w/ hokie66's 17:30 post:)
Mike
If I was...
if they're "just" warping the glass panes, and so building in stresses, what are the creep characteristics of glass ? (as bad as it's tensile props ??
Michael.
Timing has a lot to do with the outcome of a rain dance.
Doubt you have 500 years to wait!!!
Michael.
Michael.
